CFD Parametric solution
    • bilal ojaily
      Hi!
      I am studing on wing to calculate CL and CD in different angle of attack, and I heard there is a method (parametric solution) like a loop to calculate it by changing angle of wing or velocity vector
      how can I use this method?
      By setting a parameter to alter the geometry (less efficient) or inlet velocity components (more efficient). However, read through the NACA examples in Help (tutorial and/or video) as force and coefficient reporting is a little less trivial.
  • The topic ‘CFD Parametric solution’ is closed to new replies.
