August 17, 2020 at 11:28 am
ahmedshafie
SubscriberI tried to calculate Cp but i got non intuitive answers , i go to report ,forces , check center of pressure , my submarine was symmetric around x plane ( vertical plane ) so i checked it and input zero value ,i choose from wall zone the submarine and hit print , i rechecked the values in moments and its not zero at all . n -
August 18, 2020 at 2:11 am
Keyur Kanade
Ansys EmployeePlease check nArrayThere are few threads on center of pressure on forum. Please use search for the same. nThere are few threads on center of pressure on forum. Please use search for the same. nn/forum/discussion/11820/center-of-pressurennRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn -
August 18, 2020 at 3:54 am
ahmedshafie
Subscriberthanks for your reply , i already tried this formula ,and added viscous force but when calculating moment its not zero , also i open help there is nothing there can help me for center of pressuren -
August 20, 2020 at 2:01 pm
DrAmine
Ansys EmployeeAround center of pressure the moment due to pressure force is zero. There is no unique solution here and some additional input is required. Mathematically you have on LHS a matrix 3*3 whith diagonal zero and anti-symmetric (aij=-aji) time the position vector of center of pressure = RHS= Moment vector around origin (0,0,0)n -
August 20, 2020 at 3:15 pm
ahmedshafie
Subscriberthanks for your reply . the additional info is that its in symmetric plane x=0 so how can i calculate cp? n -
ahmedshafie
Subscribern -
August 20, 2020 at 6:15 pm
DrAmine
Ansys EmployeeI guess I provided the way to do that. You have the pressure force and moment around origin you then build up your matrix plus your symmetry assumption. n -
August 20, 2020 at 7:01 pm
ahmedshafie
Subscriberthanks for your generous answern
Viewing 7 reply threads
- The topic ‘Center of pressure of 3d body calculation’ is closed to new replies.
