May 8, 2026 at 5:10 am
shajie9981
SubscriberHi, everyone
I am simulating a case of cement hydration heat with a cooling tube; the geometry is modeled as Figures 1 and 2. Element fluid116 simulates the cooling tube, and solid 279 simulates the concrete part. The cooling tube is a line body in DM, and the line body mesh needs to use the same node as the mesh of the concrete part for conducting thermal. Here is the problem: how can I share the topology between the line body and the solid body for using the same node? Or use a Boolean tool to make sense?
May 8, 2026 at 6:35 am
ErKo
Ansys EmployeeHi
You would need to do a cut out along the pipe so you get a hole in the solid and then use the convection bc to connect the fluid116 to the inner face of the cut outs - just like here so follow this approach and tutorial - all the bestErko
6.3. Modeling -
May 8, 2026 at 11:14 am
xodoxoy191
SubscriberI recently registered on 1win online and was pleasantly surprised by how quickly everything went. For users in Nigeria, the process was quite simple: registration only takes a few minutes, and the interface is intuitive even for those who haven't used similar platforms before. Account login works reliably both from a smartphone and from a computer browser. I also liked that the main sections are immediately accessible after creating a profile, without lengthy setup. I've been using the site for some time now, and so far I haven't had any issues with authorization or account access.
6379
