Cells separation error lvectorref: arg(2) out of range
    • clabr
      Hello everyone,
      I am doing post-processing of my simulation and I am trying to isolate a volume of my domain. I have used the Mark/Adapt Region command and then I used the Separate Cell Zones using the Register that I have previously defined.
      After doing this I get this error for some of my simulations:
      Error: lvectorref: arg(2) out of range
      Error Object: -1
      My cells seem to be separated but I can't select the interior to export data/plotting contours, I can only use the region in Reports - Volume Integrals but the volume doesn't seem to be in my Mesh Display options.
      Does anybody know why this happens?
      Thanks in advance!
    • RK
      This probably is a scheme error. Are you using FLuent in WorkBench?
      If so, I would recommend reading the settings manually. Open the solution cell, using the TUI command ,Read_settings, read in the FFF.set, import data file, close FLuent. Fluent will write new case and data file.
    • clabr
      Hi RK It worked! Thank you very much
  • The topic ‘Cells separation error lvectorref: arg(2) out of range’ is closed to new replies.
