cdb reading/exporting
    • ALEXANDRE COSTA
      I am new to ansys mechanical/apdl . I found this attached .cdb and .dat files of arterial stent simulation.
      Wondering if I can export the settings and geometry for working inside the mechanical workbench .
      Any output is very welcome.
      Alex Costa
    • sk_cheah
      Hi Alex,
      This blog post by PADT should get you started.
      Kind regards,
      Jason
    • ALEXANDRE COSTA
      Hi Jason,
      Thanks. I am attaching the translated .wbpz
      Do you have any clue about going further ?
      The contents of .dat can be interpreted within workbench ?
      Alex
    • ALEXANDRE COSTA
      attached
    • sk_cheah
      Hi Alex,
      The CDB file contains the mesh etc while the DAT file contains the solution procedures etc. The method discussed above imports the CDB but I am unaware of how you can directly import DAT into Workbench. If it is appropriate for your problem, I would recommend solving it natively in Ansys classic.
      Kind regards,
      Jason
    • aravindaru246
      while exporting cdb file from ansys mechanical ,we get only mesh details
      But we need mesh,loading and boundary condition in same file.How to get it.
      If any solution? please suggest me.
      Thank you
    • janot.lubritz
      Is there any solution on the topic? I have the same issue that I cannot import the loads from a .cdb file that was exported from Hypermesh. The loads are present in the file (when opening it with notepad or so) but it only imports the constraints and the mesh but no loads. Is there a way to import the loads or to check where the problem is? The guides do not really help me with the issue.
Viewing 6 reply threads
  • The topic ‘cdb reading/exporting’ is closed to new replies.
