April 14, 2022 at 3:13 pm
nc952
SubscriberApril 15, 2022 at 6:43 pmKarthik Remella
AdministratorHello:
I cannot see your screenshot (error message) because it is an attached image. Please embed screenshots directly into the post.
If I were to take a guess, you will need to save (or write) the plot data. This can be done when you create your Cd and Cl plots. If you have the data file, you can recreate the plot in Fluent. I hope this helps.
Karthik
Viewing 1 reply thread- The topic ‘Cd and CL Plot’ is closed to new replies.
Innovation SpaceTrending discussions- JACOBI Convergence Issue in ANSYS AQWA
- Two-way FSI simulation
- RIBBON WINDOW DISAPPEARED
- Battery Pack cooling
- ISAT ABORT error
Top Contributors-
4597
1495
1386
1209
