March 30, 2021 at 11:18 am
March 30, 2021 at 1:18 pm
karthik.remella
AdministratorHello,
Carreau model is not available for turbulent flows. Please check if you are able to see it when you turn on the Laminar flow.
Karthik
March 30, 2021 at 1:19 pm
up201506004
SubscriberThank you for answering.
The viscosity was not laminar for some reason.
Now the option is there.
Thank you very much for all the help.
March 30, 2021 at 1:30 pm
karthik.remella
AdministratorHello,
Please go to Viscous Model -> (and select) Laminar. The viscous model is set to the Turbulent model by default.
Karthik
September 10, 2021 at 4:19 pm
September 10, 2021 at 5:39 pm
karthik.remella
Administrator.Hello,
Pick the Laminar model and then you should find the option under Viscosity (fluid properties). Which version are you using?
Karthik
Viewing 5 reply threads
- The topic ‘Carreau model option not appearing’ is closed to new replies.
