November 1, 2024 at 2:46 am
Sebastian.Xie
Subscriber -
November 11, 2024 at 5:40 am
GLUO
Ansys EmployeeHello,Inter-turn capacitance can be calculated using electrostatic solver. It is recommended to use a separated turn model, and assign voltage to each turn to represent the voltage distribution. For example, a 300-turn coil, for each turn, the voltage is different. Assuming we are applying total 1 V voltage on the two coil terminals, the voltage of each turn is300 turns and 1V: 1V/300/2 for 1st turn
1V/300*(1+1/2) for 2nd turn1V/300*(2+1/2) for 3rd turn ...
1V/300*(300-1/2) for the last turnThis represents the actual voltage distribution among the 300 turn, then we can solve it, and check the inter-turn capacitance in the matrix result.GL
1891
1419
