March 20, 2024 at 8:09 am
SIDDHARTH KUMAR
Subscriberi have a cantilever beam which is amde up of aluminium and this beam contains iron particles between 2 face sheets of aluminum so total 3 sheets in short a sandwich beam bonded together now the main thing is when the cantilevr beam is given a force on free end it will vibrate and will gain natural frequency and now i will apply magnetic field from above and bottom so when the iron particles will come in contact with the field , they will be able to stabalize beam so this is a tunable cantilever beam , more magnetic field means more stabalisation , please tell me how to do this simulation what to use what product.
March 27, 2024 at 2:39 pm
dlooman
Ansys EmployeeIt's a challenging application, but elements SOLID226/227 in APDL support magneto-structural coupling. See Section 2.8 of the Coupled-Field Analysis Guide in the APDL documentation.Â
April 2, 2024 at 5:00 pm
wrbulat
Ansys EmployeeAdding to what Dave said, the magnetostructural coupled options of SOLID226/227 are not natively exposed in Mechanical, so you would have to use command objects to at least (a) call the option into use (set KEYOPTION 1 to 10001 or 10101), and (b) define magnetic material properties (relative permeability to region occupied by iron particles) and possibly electric conductivity to the aluminum (if motion induced eddy currents and corresponding Lorentz forces are significant).Â
The presence of nonlinear (displacement dependent) forces is almost sure to force you to perform a transient analysis, with the beam initially deflected, then released. If the arrangement is such that the magnet(s) and the distribution of the forces they exert are relatively localized, you might be able to devise a lumped approximation of the magnetic force with spring elements (a less computationally expensive option). Springs can be defined in such a way as to produce nonlinear negative stiffness (with attractive forces increasing as nodes get closer) - please look at Negative stiffness in x-position between PM and steel stator (ansys.com) if interested.
I've never tried this myself, but you might be able to use the harmonic balance method in a harmonic response analysis to solve this problem (if the magnetic forces are simplified with nonlinear springs):
HBM seems a pretty steep learning curve to me - it might be simpler to start with a nonlinear transient analysis.
--Bill
- The topic ‘cantilever beam problem’ is closed to new replies.
4512
1494
1386
1209
