August 26, 2020 at 10:10 am
Aledaponte85
SubscriberHi,nMy name is Alejandro da Ponte. I am working on a simulation and I need to set up the mesh with elements smaller than 4 mm to study the influence on the stress in an specific area of the model. But when I go bellow 4 mm on the mesh option it puts the number on Yellow and doesn't let me generate a new mesh. There is no error message or anything, just the yellow marking. I know this mean that I need to change something up in the tree but I can not find what it is. I even try with a very simple model, just a small rectangle to see if it was a problem of the geometry but, the problem persist.nCan anyone help me to figure it out?.Thanks in advance to you allnbest regardsn -
August 26, 2020 at 2:06 pm
das.3
SubscriberTry disabling mesh defeaturing as I suspect that this might be causing the problem.n -
August 26, 2020 at 4:41 pm
Aledaponte85
SubscriberThank you, that workedn -
August 28, 2020 at 6:50 am
das.3
SubscriberAnytime!n
- The topic ‘Can’t set up element size smaller than 4 mm when setting up a mesh’ is closed to new replies.
