Cannot read data in CFD-Post: Error “The run ‘RunTransient’ in simulation ‘Simulation’ contains…”
    • duarterocha17
      Hello.
      I created an export CDAT for CFD-Post to read the files in CFD-Post, as it follows.
    • Rahul Kumar
      I would suggest doing a test using a simple model first to make sure data is being read into CFD Post. That being said, (a) try setting the temp folder to a different location, perhaps a different drive if you have access to it, (b) check if indeed the data files are present in the location where the software is looking.
    • Amine Ben Hadj Ali
      Also try binary export. Additionally try reading the last data file of the transient run instead of the flprj file.
      Also do not write case file every time: that is required if mesh changes snd I eill try to avoid that if my mesh is not changing.
      If you have access into Ansys EnSight also try reading there too before you start changing anything/ trying anything.
    • duarterocha17
      Hello.
      Thank you for your replies. I deleted the data export and just with the .dat files from the Autosave, I was able to load the results in CFD-Post.
      I still find it odd that having the data export into CDAT was not allowing me to read the files in CFD-Post, but I believe it was troubled by having both the .dat (from the Autosave) and .cdat (from the data export) files in the same folder.
      Once again, thank you for your time and attention, have a good day!
Viewing 5 reply threads
  • The topic ‘Cannot read data in CFD-Post: Error “The run ‘RunTransient’ in simulation ‘Simulation’ contains…”’ is closed to new replies.
