February 23, 2025 at 10:54 am
byronpiper1618
SubscriberI have a text file containing points for a curve and whenever I try to fill it in it just disappears or does nothing. I cannot understand why this is happening. It gets imported just fine and is fully connected. The points are all chained logically as verified by an external software so there's no reason why this curve should have this issue, especially when another curve I've imported works just fine.ÂIt sucks that I get no error message so I can't even diagnose what's happening, it's just nonsensical.ÂHere's the file:Here's the curve, fully connected and read in just fine. I just cannot fill in this curve: -
February 24, 2025 at 3:19 pm
Atharv Joshi
Forum ModeratorHello,Â
Which version of SpaceClaim are you using? Is it a 3D curve? If its you will have to use 3d=True.Â
polyline=false - spline curves are created.
polyline=true - straight lines are created.Have you tried this in Ansys Discovery?
Regards
AtharvÂ
Ansys Innovation Space
970
851
599
591
