April 28, 2021 at 11:54 am
practice_ping_pong
SubscriberI am interested in studying a ping pong ball's flight in the air and using Ansys 2020 R2 Fluent at the moment. How can I create the geometry model? A ping pong ball has the following characteristics:
Inner Diametre is 39.60 mm, Outer Diamtre 40.20 mm and the shell thickness 0.30mm. The weight of a ball is 2.70 g.
How do I add the air into the project? I read about treating air as an enclosure in earlier versions of Ansys CFD but I don't know how to add the air flow for my project in Ansys 2020 R2.
I would appreciate if anyone can show me step by step how to achieve the above.
Sincerely,
Xiu (practice_ping_pong)
April 28, 2021 at 2:08 pmMarco Coderoni
Ansys EmployeeHello,
The simplest approach would be to study the ball as fixed in the air volume, just to analyze how the air would flow around it. This would be a good starting point to get used to using Fluent. You can refer to this simulation example as reference:
You can then increase the complexity of the simulation as needed. In the fluid dynamic analysis, you would only to create an enclosure around a simple sphere with the external diameter you plan to use. The inner geometry is not needed. You can use SpaceClaim to quickly do this.
Hope this helps.
May 13, 2022 at 7:18 amjannifer201387
SubscriberA ping pong ball consists of:
The Inner Diameter of ping pong is 39.60 mm, the Outer Diameter is 40.20 mm, and the shell thickness is 0.30mm. The weight of a ball is 2.70 g.
May 13, 2022 at 10:19 amRob
Forum Moderatorcorrect, but if you were modelling the flow around one (in 6DOF) what would the density be?
Viewing 3 reply threads- The topic ‘Can someone help me to build a model of a ping pong ball please?’ is closed to new replies.
6600
1311
