March 26, 2024 at 8:17 am
March 28, 2024 at 10:52 pm
Guilin Sun
Ansys EmployeeI believe it is not due to comatic aberration. It might be due to the polarization. Please check if the two sports are due to the two linearly polarized light sources: use linear polarization (eg, Ex and Ey) as the source and check the images. are they angled incidence? does the metalens has 90deg rotation symmetry ?
you may also check if the simulation is wide enough to reduce the diffraction effect caused by PML truncation to the incident plane wave.Â
please provide some screenshots about the device and settings.
March 30, 2024 at 8:45 am
uzmayaqoob1960
SubscriberDear sirÂ
its basically under the normal incidence of light. We have used rotation of nanobars under Pancharnam Berry phase concept to realize inplane rotation of nanobars of same dimensions to develop a metasurface.But when we find FWHM Full width half maximum for the spot located at 0deg that is bit compromized rather than the spot focused at 90 degree.
April 1, 2024 at 3:46 pm
Guilin Sun
Ansys EmployeeUnderstood.
I guess 0 deg mean x=0,y=0. right?
So the two spots rotated.Â
Without more details of simulation settings it is hard to tell if there is a problem. It seems normal. As suggested previously, you may try to simulate two orthogonal polarization light sources and see what happens.
- The topic ‘Can someone guide me regarding focusing spots in case of metalens being modeled’ is closed to new replies.
5274
1859
1403
1257
