April 15, 2019 at 9:41 am
lai840713
Subscriber#include "udf.h"
#include "math.h"
#include "unsteady.h"
/* Material Properties */
#define R_p_CO2 3.75E-4 /*m*/
#define porosity 0.46
#define roh_ads_CO2 1138 /*kg/m^3*/
#define w_m_CO2 0.4423 /*kg/kg*/
#define K0_CO2 6.91E-5 /*mbar^-1*/
#define del_h_ads_CO2 -15000 /*J/kg*/
#define R_u 8.314 /*J/mol/K*/
#define MW_ads 0.01 /*kg/mol*/
#define n_CO2 2
#define D_s0_CO2 2.54E-4 /*m^2/s*/
#define E_a_CO2 42000.0 /*J/mol*/
DEFINE_UDS_UNSTEADY(my_uds_unsteady,c,t,i,apu,su)
real physical_dt, vol, rho, phi_old;
physical_dt = RP_Get_Real("physical-time-step");
vol = C_VOLUME(c,t);
rho = 1.0; /*C_R_M1(c,t);*/
*apu = -rho*vol / physical_dt; /*implicit part*/
phi_old = C_STORAGE_R(c,t,SV_UDSI_M1(i));
*su = rho*vol*phi_old/physical_dt; /*explicit part*/
DEFINE_SOURCE(adsorption_CO2,c,t,dS,eqn)
real p_op,P_abs,const1,source,w_eq;
real k1,k2,k_m;
p_op = RP_Get_Real("operating-pressure");
P_abs = (C_P(c,t) + p_op) * 1.0E-2; /*mbar*/
const1 = K0_CO2 * exp(del_h_ads_CO2 * MW_ads / (R_u * C_T(c,t))) * P_abs;
w_eq = w_m_CO2 * const1 / pow(1.0 + pow(const1,n_CO2), 1.0/n_CO2);
k1 = 15.0 * D_s0_CO2 / pow(R_p_CO2,2.0); /*1/s*/
k2 = E_a_CO2 / R_u; /*K*/
k_m = k1 * exp(-k2 / C_T(c,t)); /*1/s*/
source = (1.0 - porosity) * k_m * (w_eq - C_UDSI(c,t,0));
dS[eqn] = (-k_m) * (1.0 - porosity);
return source;
DEFINE_SOURCE(continuity_source_CO2,c,t,dS,eqn)
real p_op,w_eq,P_abs,const1,source;
real k1,k2,k_m;
P_abs = (C_P(c,t) + p_op) * 1.0E-2;/*mbar*/
const1 = K0_CO2 * exp (del_h_ads_CO2 * MW_ads / (R_u * C_T(c,t))) * P_abs;
source = (1.0 - porosity)* roh_ads_CO2 * k_m * (w_eq - C_UDSI(c,t,0));
dS[eqn] = -(1.0 - porosity)* roh_ads_CO2 * k_m;
return source;
DEFINE_SOURCE(energy_source_CO2,c,t,dS,eqn)
real k1,k2,k_m;
w_eq = w_m_CO2 * const1 / pow(1.0 + pow((const1),n_CO2), 1.0/n_CO2);
source = -25 *(1.0 - porosity)* roh_ads_CO2 * del_h_ads_CO2 * k_m * (w_eq - C_UDSI(c,t,0));
dS[eqn] = 25 *(1.0 - porosity)* roh_ads_CO2 * del_h_ads_CO2 * k_m;
return source;
DEFINE_SOURCE(energy_sourcesecond_CO2,c,t,dS,eqn)
real k1,k2,k_m;
source = 100000 * (w_eq - C_UDSI(c,t,0)) * (w_eq - C_UDSI(c,t,0));
dS[eqn] = -200000 * (w_eq - C_UDSI(c,t,0));
return source;
April 16, 2019 at 12:25 am
tsiriaks
Ansys EmployeeI would recommend to post this question under Physics Simulation -> Fluid Dynamics section.
You might get a proper attention there.
Thanks,
Win
April 16, 2019 at 1:02 pm
Forum ModeratorI'd also suggest posting what it does: staff are not going to debug the code, but may be able to give pointers based on what's (not) happening.Â
- The topic ‘CAN SOME ONE CHECK MY UDF’ is closed to new replies.
5849
