July 21, 2024 at 3:35 am
p fey
SubscriberHey, I am simulating a MIMO Imaging scenario in HFSS SBR+. For each excitation, the properties tab shows its "TX/RX Type" is TX/RX. Can I set a specified exciation to be Tx or Rx only?
July 23, 2024 at 8:20 am
July 24, 2024 at 2:12 am
p fey
SubscriberThank you Aymen!
- The topic ‘Can I set TX and RX separately in HFSS SBR+’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1487
1338
1172
