August 3, 2020 at 3:03 am
Keyur Kanade
Ansys EmployeeCan I see the Elemental Coordinate System in Mechanical to know the direction of bending moments? -
August 3, 2020 at 4:18 am
prajput
Yes. Once the solution is done, you can right click on Solution and insert Coordinate Systems/Elemental Triads. Once you Evaluate Results for this item, you can see the Elemental Coordinate System for the elements of the selected geometry.
August 3, 2020 at 10:03 am
Keyur Kanade
Ansys EmployeeWhat are few important points to consider regarding element coordinate system? -
August 3, 2020 at 10:23 am
prajput
 Wireframe viewing mode may be needed sometimes to see a particular triad in an element.
August 3, 2020 at 10:34 am
Keyur Kanade
Ansys EmployeeFor the ANSYS solver, it is possible for elemental coordinate systems to vary from:
1.Time step to time step.
2. Node to node -
August 3, 2020 at 10:51 am
Karthik Remella
AdministratorShell stresses are highly dependent upon Euler angles.
Viewing 5 reply threads
- The topic ‘Can I see the Elemental Coordinate System in Mechanical to know the direction of bending moments?’ is closed to new replies.
1306
