November 20, 2020 at 2:29 pmJOELGEORGESubscriberI am new to this Ansys software. I am recently doing a project of simulating a bird event. For this project I need to mesh the bird with hexahedral element (then converted to smooth particle), and the airfoil with shell elements of 0.5mm with seven integration points, with average element size of 10mm. nI just need to the procedure for doing this meshing. nThanks in advance. n n
November 23, 2020 at 6:01 pm
December 11, 2020 at 6:45 am
July 5, 2021 at 4:30 pmMaAdelSubscriber.
JOELGEORGE
I'm same in your situation
Could you tell me how you fixed, please
July 7, 2021 at 8:15 amJOELGEORGESubscriber.
Hi Maadel,
Firstly sorry for the delay in my response. Please do have a look at this youtube video by CADFEM https://www.youtube.com/watch?v=nkOMQAXxwDE, its given in Russian language, but you will get an idea to start with. Hope you will figure out with this.
Best Regards,
Joel George.
Viewing 4 reply threads
- The topic ‘Can anyone help mw with meshing a simulation of a bird strike event using SPH method?’ is closed to new replies.
Ansys Innovation Space
- LS-DYNA Installation Issues with Student Workbench 2024 R2
- Mathematical model generation stuck at 10%
- Cross-coupled stiffness elements in LS-DYNA
- LS-Dyna CESE SMP d vs MPP d solver
- CESE solver – Ignition mechanism
- Initial Stress Shell Application and HistVarCosine in LS-DYNA
- shape memory alloy material in LS-DYNA
- *** Error 40058 (SOL+58) retractor 1000002:convergence failure at time1.01E+02
- MAT072R3- concrete damage rel3 validation
- Initial Velocity Generation
624
599
591
366
