May 3, 2024 at 10:24 am
uzmayaqoob1960
Subscriber -
May 3, 2024 at 2:50 pm
Guilin Sun
Ansys EmployeeElliptically polarized light is composed of two linearly orthogonally polarized sources with different amplitude and phase difference. You can set up two orthogonal linear polarized sources with desired amplitude and phase from the ellipticity. When the phase is 90deg, it is the amplitude ratio that determines the ellipticity. Please check the definition of ellipticity definition and choose proper amplitudes.
May 8, 2024 at 9:15 am
uzmayaqoob1960
SubscriberDear Sir
can u plz let me know that if i want to fall planar light waves x polarized at an angle of incidence 20 degree then in the above snapshot i will make amplitude=1 rest settings would be set to zero but polarization angle =20 degree .Is it like so? plz respond
May 8, 2024 at 3:51 pm
Guilin Sun
Ansys EmployeeYes you can. However the incidence angle theta does not related to polarization. Phi may affect the polarization. Polarizaiton angle for a linear polarization will rotate the polarization from x-axis.
May 9, 2024 at 5:37 am
uzmayaqoob1960
SubscriberThank u sir.Plz confirm to change incidence angle of incoming light wave we will just make changes in angle theta? As i wanto to fall planar light (linearly polarized light)
Settings would be like:
Amplitude:1
phase(degree)=0
Injection axis=z-axis
direction:forward
angle(theta) degrees=20
angle phi(degree)=0
May 9, 2024 at 3:10 pm
Guilin Sun
Ansys EmployeeIt is correct for an incident angle of 20deg.
May 10, 2024 at 4:48 am
uzmayaqoob1960
SubscriberMany thanks Guilin
- The topic ‘Can any one plz guide how to generate elliptical polarized light with specific’ is closed to new replies.
6790
1332
1152
