January 21, 2019 at 4:04 am
Luther87
SubscriberBuenas noches, voy a simular el cambio de fase (condensación), de un gas acompañado de partÃculas sólidas que ingresa a una tuberÃa, la temperatura en las paredes internas de la tuberÃa es menor que la temperatura del gas, que modelo de cambio de fase me recomiendan utilizar?, Gracias. -
January 21, 2019 at 6:24 am
DrAmine
Ansys EmployeeIs the gas a pure phase or a mixture of condensable and non condensable components? -
January 21, 2019 at 9:09 pm
Luther87
SubscriberEl gas es una fase con componentes condensables y no condensables.
January 22, 2019 at 7:36 am
DrAmine
Ansys EmployeeYou can use the Wall Film Model to keep track of the condensate film formation on the wall.
January 23, 2019 at 12:42 am
Luther87
SubscriberThank you for your comments.
January 23, 2019 at 4:14 pm
DrAmine
Ansys EmployeePlease mark this topic as resolved. thanks!
Viewing 5 reply threads
- The topic ‘Cambio de fase (condensación) en pared a baja temperatura’ is closed to new replies.
1311
