December 21, 2018 at 1:25 pm
Akshay1993
SubscriberHello friends,
i have a doubt regarding power generation in wind turbine. i have calculated the moment in y axis as my rotor also rotors along y axis.but the moment is way too small. i am getting correct thrust force but i am not able to understand why my moment value is in correct. My wind turbine blade is 64.5m and i am calculating at 10m/sec inlet velocity and and at -11.357 rpm. i am comparing between spalart and k-e realizable models. Please help me guys because i need to submit my work. Â
December 21, 2018 at 1:53 pm
Keyur Kanade
Ansys Employeeplease check following.Â
https://www.youtube.com/watch?v=b9obQ6FUj5E
if this helps you, please mark this post as 'is solution' to help others on forum.Â
December 22, 2018 at 8:35 pm
Akshay1993
Subscriber thanks a lot, but i have seen this video, i am applying right procedure for finding moment but i am getting huge difference between the values i get through ansys and theoretical values . usually for horizontal wind turbine the power coefficient should be between 0.35-0.45. but i am getting 0.22. please help me out. Â
December 23, 2018 at 7:43 pm
raul.raghav
SubscriberA quick calculation shows that your tip speed ratio (TSR) is ~7.7 and the power coefficient should definitely be greater than what you're getting.
Could you post a few pictures of your mesh, setup and some of the important results -
January 1, 2019 at 12:42 pm
Akshay1993
SubscriberYes you are right Raul. The below diagram is my domain. The name selections are as follows.The inlet is from left and outlet is at right. Outer wall is enclosure. for rotor i have given interface-in, interface -enclosure, interface-out and blades. My orthogonal quality is 0.046 and skewness is shown in below diagram. i have created inflation layer with first cell height 0.01m. Done face sizing of 0.3m and edge sizing of 0.13m.
My doubt in this post is, i need to calculate moment of the blade. When i am calculating only with respect to blade my cp value is 0.22. But when i am calculating with walls i am getting cp value around 0.48. And other important point, i have noticed these walls are not shown in display. can you guys tell me which procedure is correct. These walls are appearing when i am giving the name-selection for the rotor.
January 1, 2019 at 1:03 pm
raul.raghav
SubscriberCan you show the wall-17,18,19 & 20 regions in the schematic?Â
January 1, 2019 at 1:15 pm
January 1, 2019 at 1:16 pm
January 1, 2019 at 1:35 pm
January 1, 2019 at 1:45 pm
January 1, 2019 at 1:46 pm
Akshay1993
SubscriberIn beginning the element size was 71 and i changed to 56m.
January 1, 2019 at 2:07 pm
raul.raghav
SubscriberYou need to have a conformal mesh in order to avoid the walls being automatically generated.
If you used Design Modeler: you need to select the two bodies and RMB to Form a New Part.
If you used Spaceclaim: you need to Share Topology to ensure you obtain a conformal mesh.
Let us know if you have questions regarding that.
January 1, 2019 at 2:35 pm
Akshay1993
Subscriberi have used sliding mesh technique, and i have followed many videos from youtube and videos posted from cornell univeristy. Is there any other method to resolve this issue because i have almost completed my work using spalart and kepsilon models. And i have performed the simulation using 2 million cells. it will be difficult for me to start the work again.
January 1, 2019 at 3:22 pm
raul.raghav
SubscriberAkshay, it was just a suggestion to avoid the empty walls being generated.
Would you be able to attach your workbench archive file (.wbpz) so I could take a quick look at it? Please follow these directions to upload a .wbpz file.
Can you provide a screenshot of your Mesh Interfaces panel? Did you manually define the mesh interfaces?
January 1, 2019 at 4:10 pm
Akshay1993
Subscriber my file
January 1, 2019 at 4:17 pm
Akshay1993
Subscriberyes i defined the mesh interfaces manually
January 2, 2019 at 5:35 pm
Akshay1993
SubscriberRaul did you get my file??
January 2, 2019 at 5:55 pm
raul.raghav
SubscriberAkshay, I did and I'm looking into it now. I'll get back to you soon.
January 2, 2019 at 6:45 pm
Akshay1993
Subscribertq Raghav
January 3, 2019 at 7:15 pm
raul.raghav
SubscriberAkshay, I looked into your files and I don't see any problems in the setup. The results don't match up with the expected values even on refining the mesh. What airfoil is the turbine composed of?
January 3, 2019 at 11:35 pm
Akshay1993
SubscriberIt is DOWEC 6 MW wind turbine. it has 5 DU and 1 NACA Airfoil. you can find all the values from the book https://www.researchgate.net/publication/265038104_Aeroelastic_Modelling_of_the_LMH64-5_Blade
January 6, 2019 at 12:22 pm
Akshay1993
SubscriberRaghav when you performed the mesh operation with refinement, what was the quality you achieved. and what was your meshing procedure. can you share the pics. Have you got any answers regarding my problem ???
January 22, 2019 at 9:38 pm
Akshay1993
SubscriberRaghav ??Â
February 13, 2019 at 4:10 pm
Akshay1993
Subscriberi think raghav is not answering can any one of you help me i solving this problem
- The topic ‘calculation of power’ is closed to new replies.
2979
970
857
750
599
