EssayShark offered me a worry-free writing solution from beginning to end. Once I posted my requirements, it was easy to compare writer bids and select the one best suited to my field. Communication was straightforward: the messaging system allowed me to send additional materials, outline any unique instructions, and receive timely updates on the paper’s progress. The finished piece arrived well before the deadline, featuring well-researched points, consistent formatting, and a well-organized structure. When I asked for small adjustments, the writer was quick to respond, ensuring every detail met my exact specifications. The platform’s support team was also on standby to answer any questions, making the overall experience seamless. If you need a dependable, professional writing service, EssayShark definitely deserves consideration.
January 21, 2025 at 5:04 am
prawal
SubscriberHi, I have an assembly with multiple components connected via frictional contacts, After solving In workbench mechanical we generally get Contact Pressure and Frictional stress in the result. I understand these both relate to Contact Normal Force and Contact Traction force. However Insted of Pressure I want to evaluate the Contact Normal Force. Upon exploring I didn't find any method to do so. By some workaround how can it be calculated?
January 21, 2025 at 11:41 am
Deepak
Ansys EmployeeHey,
Can you please check this post: How do I calculate force reactions (total XYZ force) for lots of contacts for all time points — Community Forum; Please make sure u turned "ON" Nodal Force. (Analysis Setting>Output Controls>Nodal Forces)
Thanks,
Deepak
January 22, 2025 at 5:09 am
prawal
SubscriberHi Deepak,Thanks for sharing the link to the discussion about evaluating Contact forces using DPF in ANSYS. This seems really helpful. I too was expecting integrating pressure with elemental area at the contact surface should help but didn't find any straightforward means to do the same in Mechanical.
I haven't used DPF features in ANSYS earlier which seems really interesting and I would like to learn more about it. Can you please share some resources from where I can start to learn more on using DPF? PS. I have intermediate experience in Python.
Best Regards,
Prawal
January 22, 2025 at 9:42 am
Deepak
Ansys EmployeeÂ
Hi Prawal,
Data Processing Framework (DPF) for developers | Ansys Developer Portal; Examples — PyDPF-Post
If you have access to Ansys Learning Hub, search for “Introduction to Ansys Data Processing Framework – course“
Thanks,
Deepak
April 10, 2025 at 9:03 am
janebisping
3266
1031
1004
859
798
