LS Dyna
LS Dyna
Cable/Discrete element forces in a local coordinate system?
    • mpola002
      In LS-DYNA, is there a way to output forces from discrete elements or cable elements in a local coordinate system?
    • Ram Gopisetti
      Discrete beam element, type 6, relative displacements, rotations, and force resultants, all are given in the local coordinate system, which is also output.
      Use with *DATABASE_HISTORY_BEAM.
      Cheers, Ram
    • Jim Day
      Adding to Ram's comments, associated with *DATABASE_HISTORY_BEAM is the keyword *DATABASE_ELOUT.
      If by "discrete element", you mean a spring or damper defined with *ELEMENT_DISCRETE, use the keyword *DATABASE_DEFORC.
  • The topic ‘Cable/Discrete element forces in a local coordinate system?’ is closed to new replies.
