February 17, 2024 at 6:35 am
denxyatx
SubscriberHello, I found a bug in the Ansys 2024 R1 coupling system, where when I interrupted the calculation process and then wanted to continue the calculation again, an error appeared like in the video "Update failed for the Solution component in System Coupling.
Update of the Coupling component failed due to the following components which require user input:
component Setup in system System Coupling"
can anyone check for this issue please?
Please ansys teams for fix this issuethis is the link of the video :
February 19, 2024 at 4:22 pm
Rahul
Ansys EmployeeHello
Looks like you are trying to restart the coupled simulation. You need to manually set the the restart point in Fluent, mechanical and system coupling.
Please follow the procudure as in given following tutorial: Restarting a Coupled Analysis in Fluent and Mechanical (youtube.com)Hope this helps!
February 19, 2024 at 4:24 pm
Rahul
Ansys EmployeeAlso, refer user manual to know about system coupling restart in workbench.
Restarting a Coupled Analysis in Workbench (ansys.com)-
February 20, 2024 at 4:20 am
denxyatx
SubscriberHello RM, thanks for replying. In that video, i dont want to restart the calculation with different time step size, but i want to continue calculation after i interupted the calculation in half of calculation. In ansys 2021 products, its not appear error like taht
February 20, 2024 at 5:59 am
Rahul
Ansys EmployeeSpecify the restart point in each participant as shown in tutorial and continue your interrupted calcualtion.
February 20, 2024 at 11:25 am
denxyatx
SubscriberOk i will try, thanks for your help
February 20, 2024 at 1:37 pm
denxyatx
SubscriberHello RM, i have tried like on the tutorial. And i cant specipy the end time of system coupling like in this video :
?si=TiqacKgddwSa1SGaPlease help me for this issue
May 11, 2024 at 10:11 pm
denxyatx
SubscriberHello rahul,
I still cant continue my calculation for system coupling. The end time in system coupling changed to yellow color and cant modify it. Please help
- The topic ‘BUG IN SYSTEM COUPLING: CANT CONTINUE CALCULATION’ is closed to new replies.
