3D Design
3D Design
Bug in mirror selection
    • Roberto Granito
      ​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​
      In version 2022-2023R1, when geometry is selected from a mirror, the parallelepiped of the selection is not seen
    • Devendra Badgujar
      Hello Roberto
      Let me check this and get back to you.
      Regards.
    • Devendra Badgujar
      Hello Roberto
      This looks like a normal mirror operation for me, unless I'm misunderstanding. If you select the line as mirror, it will set that as mirror plane.
      Can you please confirm how exactly you would like to have the mirror operation to work?
      Regards.
    • Roberto Granito
      Hello Devendra Badgujar
      The functioning of the mirror works, but when I select the box does not come out as in the attached video to understand what I select , the selection square does not come out
      Regards
      • Devendra Badgujar
        Roberto
        Ok, I understand it now. I can reproduce that problem.
        Let me check with the team and will get back to you.
        Thank you.
    • Devendra Badgujar
      Hello Roberto
      I have raised a bug 796125 for this issue. I will let you know as I get more information on this from the development team.
      Thank you.
      • Devendra Badgujar
        Roberto The bug will be fixed in the SpaceClaim 2023 R2 release.
        Regards.
Viewing 4 reply threads
  • The topic ‘Bug in mirror selection’ is closed to new replies.
