TAGGED: buckling, eigenvalue-buckling, moment, structural
September 13, 2023 at 3:17 pm
AR
SubscriberHello,
I am designing a shock absorber and I want to do the buckling analysis using FEM. In the image you can see the shock absorber with two sections joined together with a joint (fixed) and two ball joints at the ends also joined with a fixed joint each.
The idea is to check the buckling exactly at the moment of impact. At this instant, you would have the force of the impact (F) and a moment in each ball joint related to that force (M=0.2*r*F where r is the radius of the kneecap).
Other times I have performed linear buckling analyzes setting F=-1 N, thus making the Load Multiplier the maximum buckling load. However, I don't know how to do this with the Force and the two moment on the ball joints. I want to do that with the Eigenvalue Buckling. How could I do it?
Regards
September 14, 2023 at 9:30 am
Saurabh Patil
Ansys EmployeeHi AR
Try Nonlinear buckling to capture complex buckling response due to multiple loads.Â
Regards
Saurabh
September 14, 2023 at 10:10 am
AR
SubscriberHi Saurabh Patil,
How could I do a Nonlinear buckling?
- The topic ‘Buckling with multiples loads’ is closed to new replies.
2979
970
857
750
599
