December 19, 2024 at 9:06 pm
ebogetti
SubscriberHello,
I am working on tow-steered composite plate buckling, and, as a simple check, I decided to begin with column buckling. I am looking to use *ELEMENT_SHELL_COMPOSITE and *CONTROL_IMPLICIT_BUCKLE.  Ultimately, I want to use one set of shell elements, broken up into different parts, and each part is assigned a different number of plies.Â
I have successfully developed a 16-ply model that runs and gives the expected buckling load. However, when I increase the number of plies to 32, the implicit static analysis runs properly, but the buckling analysis afterwards gives a "Segmentation Fault" error. I have sufficent memory allocated, and 20 seemed to be the limit in number of plies I can use reliably before getting the error. I want to note that I have ran the 32 ply model once, and it did work. But then I deleted 8 plies, the only thing I did, and ran the model only to get the error. Any help would be appriciated. I have attached both the model and a portion of the output file showing the error.
December 27, 2024 at 9:22 pm
Reno Genest
Ansys EmployeeHello,
Do you have error messages in the mesXXXX files? You can use the following webapp to find error messages in all mesXXXX files automatically:
Also, which version of LS-DYNA are you using? Have you tried with the latest R15.0.2?
LS-DYNA (user=user) Download Page
Username: user
Password: computer
Also, which MPI are you using? If IntelMPI, have you tried with the latest 2021.13 version?
Let me know how it goes.
Reno.
5834
