October 3, 2024 at 9:32 pmLuca Di RosaSubscriber
Does Buckling analysis are supported in Discovery?
thanks
October 4, 2024 at 6:29 amErik KostsonAnsys Employee
Hi
As far as I can see one can not run a linear buckling analysiss – workbench mechanical can be used for that. See course below
https://innovationspace.ansys.com/product/linear-column-buckling/
All the best
Erik
October 4, 2024 at 6:40 amLuca Di RosaSubscriber
Hi
Actually I got this answer from Ansys GPT but could non find it in discovery
Yes, you can perform buckling analysis with Ansys Discovery. The software has been enhanced to include a new structural capability for linear buckling analysis, which allows you to evaluate the structural stability of structures. This feature is part of the updates in Ansys 2019 R3 for Discovery AIM [1]. URL: [1]Â https://www.ansys.com/resource-center/webinar/r3-discovery-live-aim
References:
[1] Title: Ansys 2019 R3: Discovery Live and Discovery AIM Update - Webinar Content, URL:Â https://www.ansys.com/resource-center/webinar/r3-discovery-live-aim.Â
thanks!
October 4, 2024 at 8:03 amDevendra BadgujarForum Moderator
Hello Luca,Â
Thanks for your reply. Buckling analysis is not yet possible in Discovery. The team has this enhancement noted and might be available in future releases.Â
Ansys GPT answer is from Discovery AIM which is a legacy product and not available to use. Â
DevendraÂ
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Crash by using Script Editor
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
1281
591
543
524
366
