November 27, 2022 at 9:56 am
November 28, 2022 at 5:16 pm
Guilin Sun
Ansys Employee这是因为材料拟合、网格尺寸以及PML可能不同造成的。之前我写过一个帖子
Ansys Insight: 光谱宽度会影响同波长的透过率吗?分段仿真如何得到光滑的结果
目前不工作,你可以找一下国内一些网站看看有没有。
基本设置是:固定材料拟合与网格计算的波长范围相同。简单的操作是这样:
你试一下。
有时也可能需要修改PML。
December 2, 2022 at 10:00 am
wuhao zhang‘’
Subscriber老师您好,我按照您的建议修改了设置,无明显变化,且PML使用Standrd,增加到14层,也无明显变化,请问还有什么方法使谱线平滑?
December 2, 2022 at 11:55 am
wuhao zhang‘’
Subscriber器件长度在1600um左右,这个会不会有影响?
December 2, 2022 at 11:13 pm
Guilin Sun
Ansys Employee14层太少,你用32,48 或者64 层看看。
器件长应该增加仿真时间,让autoshutoff min 决定何时停止仿真。
参见
October 25, 2023 at 6:32 am
Joy Marry
SubscriberHello! Inconsistent results in the overlapping wavelength portion may be caused by differences in simulation models or parameter settings. Please check the following possible causes:
Model settings: Make sure you use the same model settings in both simulations, including material properties, boundary conditions, light sources, detectors, and other relevant heardle parameters.
Discretization parameters: Ensure that the same mesh density and discretization parameters are used in both simulations. Different grid settings can lead to inconsistent results.
Wavelength range: The choice of wavelength range may affect simulation results. Make sure your wavelength range covers the spectral range of your interest.
Numerical stability: When simulating over a wide wavelength range, smaller time steps or other numerical tricks may be required to ensure simulation stability.
Initial conditions: Check that the initial conditions are the same, including the excitation mode and the initial distribution of the fields.
- The topic ‘波长范围对结果的影响’ is closed to new replies.
4954
1639
1386
1242
