Preprocessing
Preprocessing
boolean operation not working
    • swathi
      I have two solid cylinders and I have to subtract small one from the larger dia one. I tried boolean operation but unfortunately, it is not working for subtraction. for unite, intersection and imprint it is working. Why is it so?
    • Keyur Kanade
      are you using dm or spaceclaim?
    • Keyur Kanade
      if dm  -
      go to tools - analysis tools - fault detection and check if geometry has any errors.
      if spaceclaim -
      right click on the geometry in model tree and use check geometry.
      geometry should be error free for boolean to work.
  • The topic ‘boolean operation not working’ is closed to new replies.
