March 18, 2020 at 10:04 pm
glouvincs01
SubscriberHello,
In a transcient analysis , I'm using one step with bolt pretension and then another step with a shock applied on a structure. I would like to know how to chose correctly the time step for the first step? How the time matters for pretension in general ?
Thanks,
Best
March 19, 2020 at 1:29 am
peteroznewman
SubscriberIn Step 1, you turn off Time Integration, so real time is not being used while the bolt is being tensioned. You can take 1 second to tighten the bolt, then the shock load can be applied when Step 2 starts at T=1.
March 19, 2020 at 6:44 am
glouvincs01
SubscriberThank you Sir for your answer
- The topic ‘Bolt Pretension in transcient analysis’ is closed to new replies.
