October 22, 2019 at 1:23 pm
Stefano
SubscriberDear Eng-Tips community,
Yesterday I installed the ANSYS Discovery Aim Student 2019 R3
I started with the Fluid Flow simulation, and then import a geometry.Â
However, after 3 seconds or so the tab hangs and does not show any action whenever I click.
When changing tabs it takes over the visuals of the projects tab or shows only a blank white screen as can be seen in the image attached to this post.
Interestingly, I can hover over the options present in the study tab as if it was still functioning, only the visuals are gone.
Does anyone experienced this before, or even better know a solution?
Any help is greatly appreciated.
Kind regards,
Stefano
October 22, 2019 at 7:26 pm
tsiriaks
Ansys EmployeeHi Stefano,
This is likely issue with graphics on the machine. What graphics card do you have ? Also what is the driver version ?
Thanks,
Win
October 23, 2019 at 1:04 am
Stefano
SubscriberHi,
Im using graphic card NVIDIA GeForce GTX 1050 Ti Version 430.86
Stefano.
October 24, 2019 at 9:42 pm
tsiriaks
Ansys EmployeeTry updating the graphics driver to the latest available on https://www.nvidia.com/Download/index.aspx
Also, make sure your machine uses Nvidia by default , see if you have this option
Right click on the desktop then launch Nvidia Control Panel >> Manage 3D settings >> set Preferred graphics processor to be "High-performance NVIDIA processor.
- The topic ‘Blank white screen on ANSYS Discovery Aim study tab’ is closed to new replies.
4212
1493
1375
1197
