TAGGED: apdl, help, mapdl, mechanical, moving-heat-source, welding, workbench
December 14, 2023 at 8:33 pm
Alina Niederberger
SubscriberHi there,ÂI´m trying to simulate a deep welding process with a moving heat source in Ansys Workbench. The heat source consits of a conical and a cylindrical part combined, depending on the Y coordinate. So far I´ve come up with two different solutions:ÂÂ1) Applying the heat load via BFE, using a APDL Code  Basically a loop over all time steps and all elements, where h is the depth of the keyhole, re the radius of the conical part and ri the radius of the cylindrical partÂ*DO,jj,EMIN,EMAX,1  ! Selects centroid of every element, Iterates through element numbers  Y=CENTRY(jj)  *IF,Y,LT,h,THEN                           ! Heat source application    QF=0  *ELSE    X=CENTRX(jj)                           ! Centroid coordinates of jjth-element    Z=CENTRZ(jj)    CSI=Z+TempCSI                        ! Moving coordinate  *IF,Y,GE,Yi,THEN     r1=re-TempR1*(Ye-Y)                Â     QF=QF1*exp(((-3)*(X**2+CSI**2)/r1**2))       ! Heat source equation conical  *ELSEIF,Y,LT,Yi,THEN     QF=QF2*exp(((-3)*(X**2+CSI**2)/r2**2))              ! Heat source cylinder   *ELSE     QF=0   *ENDIF  *ENDIF  ÂBFE,jj,HGEN,,QF                      ! Heat generation for selected element centroids; *ENDDO2) Applying the heat load via BFE and the MAPDL Function Generator. In this case I used the same function for the heat source as in 1) and the primary Variables X,Y,Z,TIME (sattachement)ÂEven though I use the same function, the calculated results vary. What could be the reason fort hat? I understand that with BFE the load is applied at the nodes of an element.ÂAre the differences due to different calculation points in the table, as the table might be using integration points for calculations instead of nodes? What else could be a reason fort he differences?If I try the same but with BF, the calculated temperatures via those two ways are basically identical.ÂThanks in advance -
December 20, 2023 at 11:07 am
Ashish Khemka
Forum ModeratorHi,
The heat generation rate loads specified with the BF command are multiplied by the weighted nodal volume of each element adjacent to that node. This yields the total heat generation at that node.
BFE defines an element body-force load.
Ashish Khemka
- The topic ‘BFE and Function Editor’ is closed to new replies.
1313
