LS Dyna
LS Dyna
Bezier Extraction trouble with *IGA_2D_BEZIER_XYZ
    • sdotero
      I keep running into the same error when I try and do bezier extraction on my spline surface. The error is "forrtl: severe (174): SIGSEGV, segmentation fault occurred". I can get successful runs with a regular unstructured spline setup, but when I try and do a new unstructured spline surface that required adding in additional control points around each EP I get the aforementioned error. I have tried comparing the formatting of the files and I cannot find where the difference is. I am working on the most basic layout possible with 3 elements to help the debugging.
    • Ram Gopisetti
      Please paste the complete error traceback for better suggestions.
      Also, try the latest versions of LS-Dyna to see if this is a bug or a model setup issue.
      Cheers, Ram
    • sdotero
       License option : check ansys licenses only
       *            ANSYS 2021 R1          LEGAL NOTICES             *
       * Copyright 1971-2021 ANSYS, Inc.  All rights reserved.       *
       * Unauthorized use, distribution or duplication is            *
       * prohibited.                                                 *
       * Ansys is a registered trademark of ANSYS, Inc. or its       *
       * subsidiaries in the United States or other countries.       *
       * See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
       * documentation CD or online help for the complete Legal      *
       * Notice.                                                     *
       * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION       *
       * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY      *
       * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.    *
       * The software products and documentation are furnished by    *
       * ANSYS, Inc. or its subsidiaries under a software license    *
       * agreement that contains provisions concerning               *
       * non-disclosure, copying, length and nature of use,          *
       * compliance with exporting laws, warranties, disclaimers,    *
       * limitations of liability, and remedies, and other           *
       * provisions.  The software products and documentation may be *
       * used, disclosed, transferred, or copied only in accordance  *
       * with the terms and conditions of that software license      *
       * agreement.                                                  *
       * ANSYS, Inc. is a UL registered                              *
       * ISO 9001:2015 company.                                      *
       * This product is subject to U.S. laws governing export and   *
       * re-export.                                                  *
       * For U.S. Government users, except as specifically granted   *
       * by the ANSYS, Inc. software license agreement, the use,     *
       * duplication, or disclosure by the United States Government  *
       * is subject to restrictions stated in the ANSYS, Inc.        *
       * software license agreement and FAR 12.212 (for non-DOD      *
       * licenses).                                                  *
            Date: 07/25/2025      Time: 19:17:10
            ___________________________________________________
           |  LS-DYNA, A Program for Nonlinear Dynamic         |
           |  Analysis of Structures in Three Dimensions       |
           |  Date    : 08/15/2022    Time: 08:09:41           |
           |  Version : smp d DEV                              |
           |  Revision: DEV-95269-g5232bb932d                  |
           |  Features enabled in this version:                |
           |    Shared Memory Parallel                         |
           |    CESE CHEMISTRY EM ICFD STOCHASTIC_PARTICLES    |
           |    FFTW (multi-dimensional FFTW Library)          |
           |    ARPACK (nonsymmetric eigensolver library)      |
           |    ANSYSLIC enabled                               |
           |  Platform   : Xeon64 System                       |
           |  OS Level   : Linux 2.6.32 uum                    |
           |  Compiler   : Intel Fortran Compiler 19.0 SSE2    |
           |  Hostname   : m8-17-3                             |
           |  Precision  : Double precision (I8R8)             |
           |  Unauthorized use infringes Ansys, Inc. copyrights|
           |___________________________________________________|
       > i=triangle_ac1.k memory=8000M ncpu=8
      Messages file /ansys_inc/shared_files/licensing/language/en-us/ansysli_msgs.xml does not exist.
      LS-DYNA CPU Licenses Requested:   8 Available:   8
       Executing with ANSYS license
       Command line options: i=triangle_ac1.k
                             memory=8000M
                             ncpu=8
       Input file: triangle_ac1.k
       The native file format       : 64-bit small endian
       Memory size from command line:  8000000000
       on UNIX computers note the following change:
       ctrl-c interrupts ls-dyna and prompts for a sense  switch.
       type the desired sense switch: sw1., sw2., etc. to continue
       the execution.  ls-dyna will respond as explained in the users manual
          type                      response
         quit    ls-dyna terminates.
         stop    ls-dyna terminates.
         sw1.    a restart file is written and ls-dyna terminates.
         sw2.    ls-dyna responds with time and cycle numbers.
         sw3.    a restart file is written and ls-dyna continues calculations.
         sw4.    a plot state is written and ls-dyna continues calculations.
         sw5.    ls-dyna enters interactive graphics phase.
         swa.    ls-dyna flushes all output i/o buffers.
         swb.    a dynain is written and ls-dyna continues calculations.
         swc.    a restart and dynain are written and ls-dyna continues calculations.
         swd.    a restart and dynain are written and ls-dyna terminates.
         swe.    stop dynamic relaxation just as though convergence
         endtime=time change the termination time
         lpri    toggle implicit lin. alg. solver output on/off.
         nlpr    toggle implicit nonlinear solver output on/off.
         iter    toggle implicit output to d3iter database on/off.
         prof    output timing data to messag and continue.
         conv    force implicit nonlinear convergence for current time step.
         ttrm    terminate implicit time step, reduce time step, retry time step.
         rtrm    terminate implicit at end of current time step.
       ********  notice  ********  notice  ********  notice  ********
       * This is the LS-DYNA Finite Element code.                   *
       * Neither LST nor the authors assume any responsibility for  *
       * the validity, accuracy, or applicability of any results    *
       * obtained from this system. Users must verify their own     *
       * results.                                                   *
       * LST endeavors to make the LS-DYNA code as complete,        *
       * accurate and easy to use as possible.                      *
       * Suggestions and comments are welcomed.  Please report any  *
       * errors encountered in either the documentation or results  *
       * immediately to LST through your site focus.                *
       * Copyright (C) 1990-2021                                    *
       * by Livermore Software Technology, LLC                      *
       * All rights reserved                                        *
       Beginning of keyword reader                                   07/25/25 19:17:14
       Memory required to process keyword     :     179616
       Additional dynamic memory required     :    2102558
      Image              PC                Routine            Line        Source
      ls-dyna_smp_d_DEV  0000000017E9F273  Unknown               Unknown  Unknown
      libc.so.6          00007FAB1979D6F0  Unknown               Unknown  Unknown
      ls-dyna_smp_d_DEV  0000000018044E2F  Unknown               Unknown  Unknown
      ls-dyna_smp_d_DEV  000000001804594C  Unknown               Unknown  Unknown
      ls-dyna_smp_d_DEV  0000000017ED2D20  Unknown               Unknown  Unknown
      ls-dyna_smp_d_DEV  000000000045577D  dynamem_mp_lsmall         257  dynamem.f90
      ls-dyna_smp_d_DEV  0000000002E96013  dynai_                   7847  dynai.f
      ls-dyna_smp_d_DEV  00000000034C3DE6  overly_                   596  overly.f
      ls-dyna_smp_d_DEV  000000000043D219  lsinput_                  517  lsinput.f
      ls-dyna_smp_d_DEV  000000000043AD5B  MAIN__                   1553  lsdyna.f
      ls-dyna_smp_d_DEV  0000000000419432  Unknown               Unknown  Unknown
      libc.so.6          00007FAB19788590  Unknown               Unknown  Unknown
      libc.so.6          00007FAB19788640  __libc_start_main     Unknown  Unknown
      ls-dyna_smp_d_DEV  0000000000419345  Unknown               Unknown  Unknown
      ls-dyna_smp_d_DEV  0000000017E9F319  Unknown               Unknown  Unknown
      ls-dyna_smp_d_DEV  0000000018042629  Unknown               Unknown  Unknown
      ls-dyna_smp_d_DEV  00000000180424C7  Unknown               Unknown  Unknown
      ls-dyna_smp_d_DEV  0000000018042212  Unknown               Unknown  Unknown
      ls-dyna_smp_d_DEV  0000000018042A0D  Unknown               Unknown  Unknown
      ls-dyna_smp_d_DEV  0000000017FFBE34  Unknown               Unknown  Unknown
      libc.so.6          00007FAB1979FDED  Unknown               Unknown  Unknown
      libc.so.6          00007FAB1979FF30  on_exit               Unknown  Unknown
      ls-dyna_smp_d_DEV  0000000017E930E1  Unknown               Unknown  Unknown
    • sdotero
      I can also provide my .k files if that would be helpful.
