February 16, 2020 at 3:25 am
February 16, 2020 at 2:54 pm
peteroznewman
SubscriberDon't use a Fixed Support.
Do you have the stiffness data for the bearing from the manufacturer? If so you can under the stiffness values into this Bearing support. The rotation plane is a plane perpendicular to the axis of rotation.
Please reply with the full picture. How long is the shaft compared with the width of the two bearings? Are the bearings a single row of balls or are the bearings double row that has some stiffness to resist bending?
February 17, 2020 at 3:36 pm
chinguanwei
SubscriberFrom the drawing i got. it is NKIB 5902Â https://www.skf.com/group/products/rolling-bearings/roller-bearings/needle-roller-bearings/combined-needle-roller-bearings/productid-NKIB%205902
i couldn't find those stiffness value as required in ansys.
The closest i came to was basic load rating and fatigue load limit. https://www.skf.com/group/products/rolling-bearings/roller-bearings/needle-roller-bearings/combined-needle-roller-bearings#cid-490509
The whole shaft is 154.2mm long. 2 bearings will be required which is around 20mm long and will be fitted just beside the biggest diameter shaft
- The topic ‘Bearing Contact’ is closed to new replies.
6550
1311
