August 30, 2022 at 7:32 pm
drdmsthesis
SubscriberHi,
Can Multilinear Isotropic Hardening be used with BEAM188/189 elements? I was seeing some conflicting information online, while the online documentation indicates - Bilinear isotropic hardening, Bilinear kinematic hardening, Chaboche nonlinear kinematic hardening, Creep, Coefficient of thermal expansion, Damage evolution law, Damage initiation criteria, Density, Elasticity, Hill anisotropy, Prony series constants for viscoelastic materials, Rate-dependent plasticity (viscoplasticity), Rate-independent plasticity, Shift function for viscoelastic materials, Shape memory alloy (SMA), State variables (user-defined), User-defined, Voce isotropic hardening law. Bilinear models indicate fictitious stress during plastic collapse while it apprears that BEAM188/189 is not supported for a multilinear kinematic/isotropic plasticity.
Thank you -
September 1, 2022 at 3:34 pm
mrife
Ansys EmployeeHi drdmsthesis - there are several material models under the "Rate-independent plasticity" including the Multilinear Isotropic Hardening model. Mike
December 23, 2022 at 10:42 am
bhagwantP
Ansys EmployeeThanks Mike.
@ drdmsthesis, Kindly refer:
Chapter 4: Element Support for Material Models (ansys.com)
4.4. Rate-Independent Plasticity (ansys.com)
Thanks
- The topic ‘BEAM188/189 Formulations for Multilinear Isotropic Hardening’ is closed to new replies.
6730
1314
1032
