January 19, 2026 at 9:18 am
Qianfangying
SubscriberHello, I would like to ask for some advice. I am planning to use ANSYS to simulate a fiber optic sensor applied to a flexible substrate for rocket engines. I aim to conduct material and structural simulations on the flexible film substrate, as well as perform simulation studies on its mechanical properties. Could you please advise which ANSYS modules I need to learn, which software I should download, and if there are any recommended courses for this purpose?
January 19, 2026 at 2:40 pm
Forum ModeratorHave a look in Learning. Structural would be Mechanical, you may also want to look at the optical solutions. The Student bundle has pretty much everything, but may lack certain tools.Â
February 14, 2026 at 10:49 pm
novia
SubscriberHi, I tried to install ANSYS Student. However, after 99% of the installation process, this statement appears.
RSS is disabled. Performing licensing configuration via the following command...
  C:\Program Files\ANSYS Inc\ANSYS Student\v252\licensingclient\winx64\LicensingSettings.exe --mode installation fnp server add --input .
How to solve this problem?
Regards
Novia
5094
1830
1387
1248
