January 4, 2024 at 2:44 am
January 4, 2024 at 11:56 pm
Amrita Pati
Ansys EmployeeHi Wang,Â
It is hard to say if the bandstructure is accurate or if it is simulation noise. Can you increase the number of dipole sources and rerun the sweeps to ses if the bandstructure changes?
Amrita
- The topic ‘bandstructure triangular problem’ is closed to new replies.
Ansys Innovation Space
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- Import material .txt file with script
- Trapezoidal ring
- Help for qINTERCONNECT
- Absorption cross-section of AuNR excited by prism-based TIR
- Issues with getting result from interconnent analysis script
- Topology Optimization Error
- How to measure transmission coefficients on a given plane .
- Edge Coupler EME Example Issue
823
599
591
366
