October 25, 2024 at 7:53 am
October 28, 2024 at 10:13 am
Deepak
Ansys EmployeeHi,
Please restore defaults once. Then define the background colors 1 and 2. And at last refresh the project in the workbench.
Let me know if this is helpful.
Deepak K.
October 28, 2024 at 10:20 am
October 28, 2024 at 10:31 am
Deepak
Ansys EmployeeÂ
Try to open the mechanical first and then try changing the color other than white. And then rechange to white. It was working fine in 2024R2.
Thanks,
Deepak
December 12, 2025 at 4:06 am
bhuvanessh.rc
SubscriberI followed the same steps you mentioned in every sequence, but it didn't work on 2025 R2
December 12, 2025 at 4:20 am
Deepak
Ansys EmployeeHi,
One can change the background color by setting the Background Color and Background Color 2 properties to desired values under Workbench > Tools > Appearance options.Â
But if the theme inside Ansys Mechanical is set to Dark; the background color settings are overridden.Â
When you change the Color Theme, Mechanical automatically uses the background color of the selected theme (default behavior).Â
To use the background colors specified in Mechanical, open Options> UI Options > set the Use Color Theme in Geometry Window preference to No. -
December 12, 2025 at 4:28 am
bhuvanessh.rc
Subscriberthis option worked. Thank you
December 12, 2025 at 4:30 am
Deepak
Ansys EmployeeÂ
Good to know it worked. Have a good day.
Thanks
