April 11, 2024 at 4:01 pm
muhammad.younas
SubscriberHello All,
Im simulating a 6/4 dual stator axial flux motor. appling the current to stator coils and the steady state torque is looks like the attached image. How can I get the correct steady state curve, please ? Im not able to figure out the error.
its 6 coil stator, so all current excitations are clockwise.I_a=Iph*cos(2*pi*f*time)I_b=Iph*cos(2*pi*f*time-120deg)I_c=Iph*cos(2*pi*f*time-240deg)Â -
April 19, 2024 at 2:38 am
HDLI
Ansys EmployeeHello Muhammad,
   Could you run no load simulation? when current is zero, to determine if winding sequence is same with current excitation.
   You could use RMxprt to create Maxwell 3D model, and the examples are in  C:\Program Files\AnsysEM\v232\Win64\Examples\RMxprt\afpm
HDLI
May 1, 2024 at 1:00 pm
- The topic ‘Axial Flux motor’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1482
