December 27, 2024 at 3:31 pm
andreabarbagallo.ab7
SubscriberI need to model a series of composite bodies with shell elements with "layered section".
So I converted all the solid bodies into surfaces with SpaceClaim, and extended the surfaces to bring them in contact. In Ansys Workbench, being all different bodies, I have to create the contacts so that there is continuity of the movements, and no body is labile. Although I have set the Connection Group properties to define Face-Edge and Edge-Edge contacts, auto-detection only defines Face-Face contacts. Also, most of these contacts are also wrong because they bind together complanar surfaces that in reality are separated by a surface to them orthogonal, so I should have two Edge-Face contacts rather than the Face-Face contact.Do you have any advice on what to pay attention to so that these contacts are properly self-defined? I would not want to start creating them by hand, one by one....
January 15, 2025 at 2:32 pm
Govindan Nagappan
Ansys EmployeeSee if changing the options under connection group helps. You can change the option, then right click ad genetrate automatic connections.
Check the "priority" option and see if it helps
You can try edge overrides for priority.
If the entities are within the toelrance/slider value, contact region is created. You can limit contact search to a few bodies if it helps with geometry scoping.
You can use multiple connection group with different scoping to create the contacts. If it doesnt help, you may have to create manual contact regions
February 3, 2025 at 10:00 pm
SubscriberHi Govindan, thanks for your reply.
There are the settings for my Connection Group:
As you can see, it doesn't create any contact, while same configuration works in a much easier model.
What aspects of my model should I pay attention to to understand why contacts are not being created?
I know for sure, with SpaceClaim that the various surfaces are in contact, therefore certainly within the tolerance dimension.
February 4, 2025 at 2:10 am
Govindan Nagappan
Ansys EmployeeIf you already have shared topology, contact will not be created. Is the mesh connected between the bodies?
Or see if you can use Mesh connections - Mesh Connections
February 4, 2025 at 4:05 pm
SubscriberI don't have the share topology, it's the reason why i'm using contacts. share topology will mass with my mesh, i don't understend why
No, mesh isn't connected between bodies.
I'll give a look to Mesh connections. I have 244 bodies, i hope this is gonna work
- At least one body has been found to have only 1 element in at least 2 directions
- Script Error Code:800a000d
- Element has excessive thickness change, distortion, is turning inside out
- Elastic limit load, Elastic-plastic limit load
- Image to file in Mechanical is bugged and does not show text
- Help to do quasistatic analysis in static structural module
1932
823
599
591
366
