November 2, 2021 at 10:46 pm
joekerch
SubscriberHi,
I am trying to simulate force on a diaphragm that results in a change in pressure of a chamber. I am able to set up this simulation without any fluids inside of the chamber and it returns deformation results. The goal is to place a trapped fluid inside of this chamber so that the change in force on the diaphragm results in a change in pressure of the fluid as the diaphragm deforms slightly.
I am now working to assign HSFLD242 elements to the inside walls of the chamber under the diaphragm. I am not familiar with APDL (trying to learn) and am attempting to add the HSFLD242 elements using a commands object in the workbench static structural tree. I have edited the code from this example to fit my project the best that I could. Here is the edited version, where the inside walls of the chamber are named "walls'
! Be careful with UNITS because of the material propertites. <<<==========
! It is assumed that NO SYMMETRY effects are in this model.
fini
/prep7
*get,typemax,ETYP,,NUM,MAX ! max defined element type
*get,realmax,RCON,,NUM,MAX ! max defined real constant
*get,mat_max,MAT,,NUM,MAX ! max defined material
*get,nodemax,NODE,,NUM,MAX ! highest numbered node in model
! Create a new higher number for element type, real, and material
newnode=nodemax+1000 ! number for pressure node for HSFLD242
newnumber=typemax+1
*if,realmax,ge,newnumber,then
newnumber=realmax+1
*endif
*if,mat_max,ge,newnumber,then
newnumber=mat_max+1
*endif
et,newnumber,HSFLD242 ! 3-D Hydrostatic Fluid Element
keyopt,newnumber,1,0 ! UX, UY, UZ, plus HDSP at pressure node
keyopt,newnumber,5,1 ! Fluid mass calculated based on the volume of the fluid element
keyopt,newnumber,6,1 ! Incompressible
mp,dens,newnumber,1.0e-9 ! Density of Water, kg/mm^3/1000
! Ignoring thermal expansion in this example
! Ignoring TB,FLUID in this example
r,newnumber ! Ignoring Reference pressure for compressible gas
type,newnumber
mat,newnumber
real,newnumber
cmsel,s,walls ! Select nodes on interior
esln ! Select elements that touch these nodes
n,newnode,0,0,0.07 ! Pressure node at 0,0,400 (automatically moved to centroid?)
ESURF,newnode ! ESURF HSFLD242 elements over solid element faces
! Extra node “newnode” with ESURF with HSFLD242
allsel
fini
/solu ! return to solving
When I hit solve, the program does not converge and it returns errors. Any help on how to assign the HSFD242 elements to this would be appreciated, I can share more from the workbench project if needed.
November 3, 2021 at 6:32 amErKo
Ansys EmployeeHi
Can you please include the error message found in the solution information?
Thank you
Erik
Viewing 1 reply thread- The topic ‘Assigning HSFLD242 elements to enclosed surfaces using APDL command objects in Workbench’ is closed to new replies.
6410
