Electronics
Electronics
Assigning Halbach 60 degrees magnetization
    • abankusomari
      Please how do we assign halbach 60 degrees magnetization in ansys maxwell for a magnets.Thank you
    • abankusomari
    • GLUO
      You need to creat relative coords or object coords for each magnet, and then they can use their own coords for their magnetization.
      GL
    • abankusomari
      thanks Sir i understand what you said but my problem is getting the 60 degrees magnetization .i have challenges .Can you please address it for me
    • GLUO
      The coords are rotated and off by 60 degree, then manetization is off by 60 degree. Please elaborate your challenges.
      GL
      • abankusomari
        please i am confuse about it .i need clarity .Thank you
    • abankusomari
      let us consider the magnet which has been circled below is how i did my magnetization
      please Sir have i done the right thing?
    • GLUO
      It is correct only if you are using FaceCS.
      GL
Viewing 6 reply threads
  • The topic ‘Assigning Halbach 60 degrees magnetization’ is closed to new replies.
