Assign Pressure and mass flow rate at inlet in Fluent
    • bolbol
      I was trying to assign the pressure and the mass flow rate at inlet for my case in Fluent, but after some research, I've found that u can't do that because it's mathematically over specifying.
      But someone suggest that i can use UDF to override this part, can this method work? and where exactly i just use it, in mass flow rate condition or in pressure-inlet condition?
    • Raef.Kobeissi
      You can't do both unfortunately as it is mathematically obsolete. Your inlet boundary condition has to include one of 2 options and only 1:
      -Inlet Pressure
      or
      -Velocity or mass Flow
      At the outlet, on the other hand, you can specify an outlet pressure.
      Regards
  • The topic ‘Assign Pressure and mass flow rate at inlet in Fluent’ is closed to new replies.
