April 3, 2024 at 1:06 pm
Saad Sultan
SubscriberHello Everyone,
I'm having a problem in importing a mesh done in Spaceclaim and opening it in Workbench Mechanical. The mesh is successfully generated in Spaceclaim. I get the following error:
I have tried different meshes finer as well as coarse, changing the elements as well. I have also tried the solution mentioned in a post:
/forum/forums/topic/assembly-failed-error-assembling-pmdb-and-acmo-files-value-doesnt-fall-within-expected-range/
But still the problem persistsÂ
Thanks in advance.
April 5, 2024 at 6:39 pm
mjmiddle
Ansys EmployeeThere were a lot of recommendations in the post you linked that should be valid for your project too. Have to tried all of these:
- Disconnect system linkages from all other systems that are upstream to the Model cell you want to open, except if your SpaceClaim session is from a standalone geometry system. Keep that one linked to the downstream analysis system "Geometry" or "Model" cell.
- Clear the mesh in SpaceClaim and generate.
- "Reset" downstream Model cell.
- Delete all model cell linakges, "Reset" the Model cell, and connect the Geometry system again.
- Find .mechbd in project. Copy to outside of project, and rename to .mechdat. Import into a new, empty project, and specify the scdoc file from the old project on the Geometry cell.
Make sure "Save Mesh Data in Separate File" is off since this can sometimes cause a problem in assembled models and mesh-based geometry inputs:
- The topic ‘Assembly Failed. Error assembling pmdb and acmo files: Max Id is not correct’ is closed to new replies.
