ask Residual graph sudden increase in the middle of computation in ANSYS FLUENT 17.2
    • teguhhady
      Dear all,
      I am simulating heat transfer in turbulent plain straight tube. length of the pipe is 3 m. Inlet: velocity Inlet, Outlet: Outflow, wall: constant temperature. While running the simulation I get sudden increase in residual graph then the residual graph decreases slowly (finally converged). What does it mean? Is my solution is ok because residual get converged in the end of simulation?
      PS.I attach the residual graph
    • Amine Ben Hadj Ali
      You can ignore it and stick to the fllux omblances from Flux Report as well as monitor key global quantities to judge convergence. The increase might be due to some pressure/density range treatment as you are using outflow boundary conditions.
  • The topic ‘ask Residual graph sudden increase in the middle of computation in ANSYS FLUENT 17.2’ is closed to new replies.
