TAGGED: ansys-student, ansys-workbench, mechanical, rocky-dem
February 21, 2026 at 5:53 am
hamidah.salem
SubscriberIs there a way to create a multi-layer particle, i.e. an ovoid core with a semi-soft shell made of different material and with different mechanical properties? I'm trying to create a de-shelling machine simulation. I'm new here so forgive me for the lack of knowledge. Another route I'm thinking of is to create a new geometry for each little piece of particle, but I'm not sure if it is the only possible solution.
March 25, 2026 at 2:07 pm
Jackson Gomes
Ansys EmployeeHy Hamidah.
Not directly. Rocky does not support multi-layer particles (core–shell with different materials) as a single particle.
You can use bonded particles or approximate using breakage/bond models
For more details, see the Rocky User Manual
Hope this helps!Â
If you'd like to explore more learning materials about Rocky software, you can find them here: https://innovationspace.ansys.com/ais-rocky/
Warm Regards,
Jackson
6034
