Are more than 15 inflation layers needed to resolve a thermal boundary layer.
    • Karl19
      I am investigating the flow in a simple rotor-stator cavity. Are more than 15 inflation layers needed since the thermal boundary layer needs resolving?
      Also, does the standard method of obtaining the First Layer Thickness for a flow along a flat plate apply to rotational flows?
    • Keyur Kanade
      For thermal, you can use 5 to 10 layers.
      For first layer thickness, it is similar to boundary layers. Please check following post.
      Near wall treatment ÔÇö Ansys Learning Forum
      Regards Keyur
  • The topic ‘Are more than 15 inflation layers needed to resolve a thermal boundary layer.’ is closed to new replies.
