March 20, 2020 at 4:49 pm
jakehaley9
SubscriberHi,
I'm attempting to simulate wear using the Archard's wear model built into ANSYS. I have activated the wear model through inserting an APDL command into the contact between my two components as shown:
K=0.000117
H=480 !hardness, MPa
m=1 !exponent on contact pressure
n=0 !exponent on relative pressure velocity
TB,WEAR,cid,,,ARCD
TBFIELD,TIME,0
TBDATA,1,0,H,n,m
TBFIELD,TIME,2
TBDATA,1,0,H,n,m
TBFIELD,TIME,2.01
TBDATA,1,K,H,n,m
TBFIELD,TIME,20
My problem is that if I run the model with and without this command, the deformation plotted stays the same. Does anyone have any ideas as to what the problem could be?
Thanks.
March 6, 2022 at 11:07 am
averageMechGirl98
SubscriberHi jakehaley9 ,
I am having a similar problem and cannot seem to get the wear volume or results.
If you have solved this problem, could you help me out too? I'd really really appreciate it
Thanks a bunch !!
April 22, 2022 at 4:24 pm
wrd
SubscriberHi averageMechGirl98 ,
I am a student new to wear analysis, can you share me a case of wear analysis using APDL?
454575601@qq.com is my e-mail.
Thank u so much!!!
谢谢!!!
- The topic ‘Archards Wear in ANSYS Mechanical’ is closed to new replies.
6625
1311
