Ansys Products
Ansys Products
AQWA – Export DATA CSV File
    • Eugenio Baita Saavedra
      Is there a way to automatically generate a CSV file (or update the existing one) each time a time domain analysis is finished. Or you have to go here (see photo below), every time you want to export data.
      Cheers,
    • Mike Pettit
      Hello Eugenio,
      To do this you will need to run AqwaReader as a post-solve command - there are detailed instructions included in the AqwaReader Manual, as well as a Python script that you can get started with. You should be able to access the manual from within the Aqwa Workbench editor:
      • click the Help menu on the top toolbar
      • click to open any of the Aqwa Manuals in the list
      • once the Ansys help website opens, click 'Aqwa 2023 R1' in the top left corner of the page to see the full list of Aqwa documentation
      • select 'AqwaReader Manual'.
      I would suggest reading through the whole AqwaReader manual as there is important information in each section (it's not very long). I hope this helps.
      Mike
  • The topic ‘AQWA – Export DATA CSV File’ is closed to new replies.
